Pontiac Streamliner--->noch zu retten?
Servus
Wäre diese Karre noch zu reden?
Hier die Beschreibung des Verkäufers.Inkl.der Fotos.
The Surf grey 1950 Pontiac Streamliner Silver Streak Eight 2 door fastback sedan is a mostly complete classic car ready to be restored. The body has solid, straight, no-rust western desert sheet metal. The car has many options including factory sun visor, grill guard, rear window wiper, backup lights, windshield wiper washer, electric clock and deluxe steering wheel. The right headlight trim ring is on the front seat. The hood ornament is missing. The right parking light lens is broken.The left door has been sprung and the sheet metal is bent along the hinge seam. The right door trim is missing and the right chrome rock guard is dented. The deck lid is damaged where it was pried open and the Pontiac badge is broken and missing the center piece. The right backup light lens is broken and the left license plate light assembly is missing. The left upper corner trim bar is missing. There are small dents in the rear bumper guards. The car has aftermarket rear wheel skirts. There are four stock hub caps in the back seat. The black and white interior is all there except the optional radio, shifter knob and cigarette light are missing. The 268 CID L-head inline eight cylinder 108 HP motor is complete. It looks like a runner because nothing has been taken off the motor. The car has an optional automatic transmission. The running and driving condition is unknown. Do not miss this chance to restore or customize a very desirable 50 Streamliner fastback two door sedan.
Hier noch die Antwort,welche ich via eMail bekommen habe.
This 1950 Pontiac Streamliner Silver Streak 8 two door fastback is a super-straight, solid project car. It has a factory sunvisor. The glass is all good. All the trim is there except the right door trim is missing. The right fender guard is dented. The Pontiac deck lid badge is broken and the hood ornament is missing. The dash is complete except the radio is missing. The interior is all there. The motor, radiator and transmission are missing.
- albandy
Retten kann man (fast)alles.
Bei dem ist es 'ne Frage der Wertigkeit...retten kann man den sicher. Die Frage ist immer, was hat man vor damit und wie gut sind die Kontakte der Zulieferer und Helfer. Komplett original mit Originallack, Rat Rod, oder Hot Rod. Am einfachsten und günstigsten wäre, den so zu belassen, das nötigste in Technik und Konservierung investieren und gut ist. Reinstecken wirst vermutlich einiges, vor allem Technik, Fahrwerk, Gummis, Dichtungen, Bremsen, Interior, etc..da kommt was zusammen...rausbekommen wirst bei dem Modell sicher nie das, was du reinsteckst.
Positiv ist natürlich, daß er außen komplett und gerade erscheint, das einzige optische Manko, das ich sehe, ist die aufgebrochene Heckklappe und ein zwei fehlende Leisten. Der Boden vorne schaut ganz gut aus, ebenso die Heckablage.
Die Fragen werden sein, wie sieht der Rest aus, Unterboden, Einstiege, Kofferraumboden, Radkästen...Detailbilder würde ich anfordern und wenn er'n Tausender kostet, würde ich Ersatzteile und vielleicht noch'n paar andere Dinge mitimportieren, sodaß er finanzielltechnisch abgesichert ist.
Wennst für den noch teure Ersatzteile extra importieren muß, wirds sauteuer.
Fazit: man muß schon verliebt sein, in das Modell, wenn man sich sowas rüberholt, nicht weil er schiach wäre, eher weil es nichts Außergewöhnliches ist..
Good luck!
Good luck!
albandy hat geschrieben:Retten kann man (fast)alles.
Good luck!
Servus
Wenn,dann in diese Richtung.
Aber mal schaun,was noch so alles an Infos von denen kommt.
Bei welcher Amikarre is das schon der Fall,glaub bei fast keiner.
- mares
- mares
will da wirklich keinem zu nahe treten, aber ein derartiges Auto in dem Zustand von drüben rüber holen wo der wiederverkaufswert bei uns auch ned so der bringer ist, wäre schon ein wenig, tja wie drück ichs aus, deppad
ist man Vorort und bringt die Karre selber zum laufen das man den Hafen ohne probs ansteuern kann wäre das wieder eine andere Geschichte.
Ausser ich liege da jetzt falsch und das Ungetüm steht beim Nachbarn im Garten als Blumenkiste..das ist wieder eine andere Geschichte.
Sollte kein sentimentaler Wert dahinterstehen sondern einfach..ich mach das jetzt damit ich der ganzen Welt beweisen kann das ich das auch kann, würd ich´s lassen.
Ich schreib das nur da ich vor Jahren genau das gleiche Ungetüm in genau dem gleichem Zustand drüben beim vorbeifahren gesichtet habe und dann auch genau mit dem gleichen Gedanken gespielt haben. Aber eine einfache kosten - nutzen Rechnung geht da bei weiten nicht aus.. nedamol in 20 Jahren
"Do a burnout and feel happy"
mares hat geschrieben:will da wirklich keinem zu nahe treten, aber ein derartiges Auto in dem Zustand von drüben rüber holen wo der wiederverkaufswert bei uns auch ned so der bringer ist, wäre schon ein wenig, tja wie drück ichs aus, deppad
Machst du nicht
- albandy
vn800 hat geschrieben:albandy hat geschrieben:rausbekommen wirst bei dem Modell sicher nie das, was du reinsteckst.
da gibts aber genügend...vorwiegend 2door und Coupes...aber das ist ein anderes Thema, jeder wie er meint
Was mir dazu auf Anhieb einfällt:
Das heisst im Amiland-Verkäufer-Deutsch: Motor und Getriebe sind physisch vorhanden. Weil wir es nicht zum Laufen gebracht haben und das Getriebe staubtrocken ist, gibts auch keine näheren Details dazu. Kauf es, du dämlicher Europäer und geh sch....
Später heisst es: except the motor ..... na was jetzt.
Teile für diese alten Motoren gibts zwar, aber nicht günstig und oft nur gegen *core*. Das heisst Teile hinund her schicken, zumindest bei *Kanter* ist das so.
Meine persönliche Meinung: Das Ding eignet sich hervorragend als Deko z.B. vor einer Disco oder so, aber auf die Strasse kommt der so bald nimmer.
PS: Natürlich kann man den wieder herrichten, wichtig sind der Zierrat und das Glas, alles andere kriegt man schon irgendwo her.
Auf original wird es vermutlich ein Fass ohne Boden, auf Rat Rod oder so (mit Chevy SB etc) wärs noch machbar, einfach so fahrbar machen wie oben geschrieben ........ ich weiss nicht.
meine pers. Meinung:
(ich bin ja grad mitten in der Resto von meinem 46er Streamliner)
wie die anderen schon sagten, zu richten ist alles
Kosten/Nutzenrechnung darf man hier nicht anstellen...es muss gefallen und spaß machen !
die Kernfrage ist, wie schaut er unten aus ?
vom Blech her ist es ziemlich schwierig, das ist zwar ein Fischer Body (die Kiste wurde auch von Chevy, Cadillac und Olds angeboten). Ersatzbleche hab ich nicht auftreiben können !
meiner sah auf den ersten und sogar zweiten Blich recht gut aus aber nach dem Sandstrahlen hatte ich Tränen in den Augen !
Chassis: alles lieferbar, jedes Lager, Hülsen, Dämpfer....
Glas; soweit ichs erkennen kann ist nur die Heckscheibe gebogen, die geraden kann jeder Glaser...
Zierteile, Leisten,.. fast nicht zu bekommen !
Gummis: hab grad ein Set für die ganze Kiste bekommen ...easy
Motor und Anbauteile: diese Motoren waren ausgelegt für: first Service ab 100.000 Meilen...im Normalfall lässt sich der gut wieder herstellen.
oder neuer Motor rrein (ev. billiger und einfacher als den alten zu revidieren...)
Innen...muss komplett neu ! Sattler...viele Euros
Chromteile fast nicht zu bekommen, schauen aber auf den Fotos nicht schlecht aus
...muss unter Hobby laufen (Geld lässt sich da keines verdienen !
ABER: vom Design her eine super Karre !
wennst was brauchst (Adressen....Büdln etc gerne...)
Alfred
- Daddyohs
ich hab da einen zu verkaufen der schon in Österreich Typisiert ist und Pickerl hat bis Mitte 2017. Bei Interesse einfach mal durch klingeln.
Hier der Link:
https://www.willhaben.at/iad/gebrauchtw ... 144973807/
MFG
Andy
Hier der Link:
MFG
Andy
Daddyohs hat geschrieben:ich hab da einen zu verkaufen der schon in Österreich Typisiert ist und Pickerl hat bis Mitte 2017. Bei Interesse einfach mal durch klingeln.
Hier der Link:
MFG
Andy
Weiss ich,das der zu kaufen is.
Brauche arbeit,keine fertige Karre.
- Daddyohs
vn800 hat geschrieben:Daddyohs hat geschrieben:ich hab da einen zu verkaufen der schon in Österreich Typisiert ist und Pickerl hat bis Mitte 2017. Bei Interesse einfach mal durch klingeln.
Hier der Link:
MFG
Andy
OK
Alles kann man wieder richten, geht nicht gibt's nicht. Habe einen 41er und 49er chevi Aufgebaut die vom zustand wesentlich schlechter waren, allerdings hab ich nicht so viel wert auf Originalität gelegt was die Sache einfacher macht.
47-54 Chevy-Truck Projektauto gesucht
