No. 342 / driver
No. 342 / driver
Wir suchen ein bestimmtes Auto aus den 60ern. Folgendes Datenblatt eines bekannten Magazins wird bei Bedarf nach und nach ergänzt.
Marke, Type, Baujahr sind gefragt.
Cylinders: 8
Bore & Stroke: 4.08x3.23
Displacement: 343 ci
Compression ratio: 10.2 :1
Maximum Horsepower: ???
Maximum Torque: 365@3.000
Valves:
Intake: 2.025 in.
Exhaust: 1.625 in.
Camshaft:
Lift: 477 in. intake, 477 exhaust
Duration: ???
Carburetion: ???
Exhaust System: 2.0 in. exhaust pipe, 2.0 in. tailpipe
Transmission:
Type: borg warner 3-speed auto
Differential:
Type: ???
Ring Gear Diameter: 8.75 in.
Ratio: ???
BRAKES:
Type: Disc Front, drum rear
Dimensions:
Front: ???
Rear: 10.00 in.
Swept area: 371 in.
SUSPENSION:
Front: ind. direct action coils
Rear: Parallel leaf springs
Stabilizer: 94-in. diameter
Tires: ???
Rims: ???
Steering Gear:
Type: power-saginaw
Turning circle: 36.8 ft.
Turns of sterring wheel, lock to lock: 3.6
Performance:
Standing Quarter mile: ???
DIMENSIONS:
Wheelbase: ???
Front track: 58.36 in.
Rear track: 57.0 in.
Overall height: ???
Overall width: ???
Overall length: ???
Curb weight: ???
Test weight: ???
Crankcase capacity: 5 qt.
Cooling system: 14 qt.
Fuel tank: ???
Cylinders: 8
Valves:
Intake: 2.025 in.
Exhaust: 1.625 in.
Camshaft:
Duration: ???
Carburetion: ???
Transmission:
Differential:
Type: ???
Ratio: ???
BRAKES:
Dimensions:
Front: ???
Rear: 10.00 in.
Swept area: 371 in.
SUSPENSION:
Tires: ???
Rims: ???
Steering Gear:
Type: power-saginaw
Performance:
DIMENSIONS:
Wheelbase: ???
Overall height: ???
Overall width: ???
Overall length: ???
Curb weight: ???
Test weight: ???
Fuel tank: ???
Zuletzt geändert von Driver am Donnerstag 14. Dezember 2006, 23:05, insgesamt 1-mal geändert.
- heli
- Roddin28
- tonnotossico
- tonnotossico
