was für ein motor hab ich drin
- hellmachine
hallo hab heute zufällig mall die motornummer bei meinem motor gesucht um sie mit dem typenschein zu vergleichen hab dann festgestelt das die nicht überein stimmen kann das ich vielleicht nur eine 5l maschine drin habe oder wie kann ich das herausfinden . kann mir jemand sagen was das für ein motor ist motornummer V0331CHH
- mares
CHH 1978 350 auto trans. LM1 L 170 4 full size
Engine ID Code Example: V0107CLJ - (V = Plant, 01 = January, 07 = 7th Day, CLJ = Engine Suffix Code)
Another example: T0830CTY - (T = Tonawanda, 08 = August, 30 = 30th day, CTY = 1970 396 Camaro, 375 hp, 11.0:1, TH400)
Code Engine Plant Code Engine Plant
F Flint (Motor) S Saginaw Service
H Hydramatic T Tonawanda
K St. Catherines, Ontario V Flint (Engine)
(McKinnon Industries Canada)
M GM of Mexico
vergessen: quelle:
http://www.nastyz28.com/chevy-engine-code-stampings.php
M GM of Mexico
vergessen: quelle:
"Do a burnout and feel happy"
- mares
Erik Boattail
Re: was für ein motor hab ich drin
Next time also post the make and model year of the car in question.hellmachine hat geschrieben:motornummer V0331CHH
On the front of the engine you will find a partial VIN, identifying the model year and make of the car the engine came in from the factory.
If the last 6 digits are the same as on the car's VIN, the engine belongs to this car.
At the rear of the engine, on top of the bell housing (where the engine meets the transmission) you wil find the engine casting number.
On Chebby engines the ignition is in the wrong spot, so you need to look carefully to find this casting number.
V = Engine was built at the Flint, Michigan factory.
03 = March
31 = Day of month
VHH = Model year 1978 full-size Chevrolet engine.
350 CI / 5735 CC, 170 HP @ 3800 rpm, 270 Lbs-ft of torque @ 2400 rpm, 8.2:1 compression ratio, 4 barrel Rochester carburator.
- hellmachine
Erik Boattail
What's there not to understand about this:
350=350, in both German or English......
Erik Boattail hat geschrieben: VHH = Model year 1978 full-size Chevrolet engine.
Erik Boattail
Erik Boattail hat geschrieben: 350 CI / 5735 CC
- mares
- hellmachine
