chevy
- robin winzer
chevy
Wer kann mir was zu einem Chevrolet Werk in Belgien erzählen? den mein 66er bel air schein da gebaut worden zu sein!
- robin winzer
sotsch
Du hast im Forum: Fahrzeuge des Ford Konzernsrobin winzer hat geschrieben:den check ich nitSamy hat geschrieben:also noch falscher könnte das gewählte forum wirklich nicht sein
Angebote über Autos der Marken (US)Ford, Lincoln, Mercury - ausschließlich für eigene private Anzeigen
geposted.
ist jetzt ins richtige Forum verschoben worden.
- robin winzer
- ryoga
Hab nicht viel gefunden.
Nur das das Werk bei Antwerpen steht und seit 1924 Autos baut.
und aus der Quelle camaros.org
In addition to the US assembly plants, many hundreds (if not several thousands) of Camaros were assembled by at least four overseas factories: the Yutivo factory in the Philippines (the subject of a CRG research article), GM Continental in Belgium, GM Suisse in Bienne, Switzerland, and a little-known assembly plant in Caracas, Venezuela. The last three factories remain objects of continuing CRG research, and if you have information on any of these facilities, or cars built at them, please contact us.
These plants and the export activities were managed by GMOO (GM Overseas Operations) and GMODC (GM Overseas Distribution Corporation). We would be interested in talking to anyone that has worked for either of these GM groups.
The Philipine, Swiss, and Belgian factories all assembled vehicles from "completely knocked down" (CKD) kits; as the name implies, kits from which bodies were fully assembled from individual separate sheet metal stampings. Parts and subassemblies for CKD export units were shipped to a central collection point, gathered together and consolidated into kits, then packed into containers for shipment overseas. There were generally six CKD kits to a container; with twenty-four cars in the typical export car order (XCO), that meant four containers per XCO. The CKD kits were reportly consolidated at a "box plant" in Michigan.
Gruß Martin
Gruß Martin
- robin winzer
- Haegar
stimmt - hab ich heute wieder an einem X5 erleben duerfen...Gustavltd hat geschrieben:Wenn ein Europäer so arbeitet wie ein Ami punkto Qualität wird ihm das Fahrzeug um die Ohren geworfen!!!!
