Chevrolet Colorado Rally Concept
Beitragvon tobi » Freitag 17. Juni 2011, 12:21
Press Release:
Chevrolet introduces the second concept of the next generation of pick ups in the 5 th International Motor Show in Buenos Aires
16/06/2011
Rally Colorado Concept conveys strength, power and capacity
Design developed by the GM Design Center South
Buenos Aires, Argentina – Chevrolet revealed in the 5 th International Motor Show in Buenos Aires, Colorado Rally, the second concept of what will be the next generation midsize pickups global brand. The premiere of the Rally version, following the presentation of the first Concept of Colorado Hall of Bangkok last March. These two pick ups will allow us to visualize how the next generation of pick ups global brand.
The tradition of Chevrolet pickups were characterized by their robustness and strength. This concept combines design elements from Chevrolet’s legendary ability to develop vehicles with excellent performance both on and off the road.
“We are honored to be posted in Argentina for the first time in eastern Concept symbolizes the evolution of Chevrolet pickups in the world. We celebrate with pride the development of GM South America, “said Sergio Rocha, President and CEO of GM Argentina, Uruguay and Paraguay.
For the construction of the Colorado Rally, GM designers in South America, conducted extensive research on this subject. Every item developed for this Concept was designed to improve vehicle performance in all fields and also to help the pilot and navigator.
This Concept is a version of pick-up double cabin, equipped with four-wheel drive, aluminum rims 18 “double-ended (machining and polishing) and 305/60 R18 tires. The power of the Colorado Rally Concept comes from an efficient 2.8-liter turbodiesel engine that delivers excellent torque for this car rally.
The Colorado Rally Concept has features that allow even better prepared for the off-road activity. It has high performance shock absorbers 140mm and a remote reservoir with fluid. It is also equipped with a system that allows you to increase during the suspension at 5 centimeters and consequently the height relative to the floor.
Both the front and rear, the Rally Colorado is equipped with integrated winch to the bumper, 5.5 hp, with a capacity of 4 tons of traction and reinforced steel cables 23 meters long.
Design details
Painted white pearl, the Colorado Rally Concept, has unique features developed by the GM Design Center in South America, exclusively for this vehicle. The windows are made of acrylic, which ensures greater protection from side impacts and also have holes for air circulation, as temperatures inside a rally car can exceed 50 degrees Celsius.
As for the bodywork, Colorado Rally, has a roll bar, support for the spare tire in the box and other decorative details in color “Charcoal” textured. Also in the box, this pickup has a plastic protector and a box of tools specifically developed for this Concept. It also has running boards stylized fueling nozzle exposed executed in aluminum. In order to improve aerodynamics and reduce vehicle weight, the designers have chosen to introduce a perforated back cover.
“Robust and aggressive lines of the Colorado Concept, presented in Bangkok were the perfect foundation for building a car rally. Certainly, with the debut of the Concept in the Hall of Buenos Aires will have a preview of what we see on the roads around the world in a while, “said Carlos Barba, General Director of GM Design America.
“The Concept Rally Colorado is looking to the future of the global Chevrolet pickups. With this concept, the brand demonstrates its leadership in building vehicles with great design and capacity, “said Brad Merkel, Executive GM Global Vehicle.
All external lighting of this pickup is comprised of lamps and lights that use LED technology. The Colorado Rally Concept has sidelights and high performance lighting incorporated into the outside rearview mirrors, as well as long range lights on the ceiling and auxiliary lights on the front bumper.
Inside: a separate show
The interior of the pick up Colorado Rally Concept is focused on ergonomics and functionality. The top of the dashboard is covered in textured leather color “Very Dark Grey Ash” and was fully adapted to incorporate the tools in a race car.
The center console, for example, has pressure and temperature gauges and controls that adjust the tire pressure, the hardness of the dampers, operate fire extinguishers and additional fuel pumps.
The sports steering wheel has a flattened curve and a set of LEDs indicating engine speed (the most important indicator for the pilot), allowing you to find the best time to shift gears. It also has four command buttons that alter the central display panel (alternating different information like a computer board), turn on the headlights, the Air Boost (a compressed air system that cleans the air quickly cabin, in situations where the vehicle is in a cloud of dust) and the speed limiter in the urban stretches.
The seats are sporty Colorado Rally Concept, type “shell” and has seatbelts five points that allow a total clamping of the pilots. They are lined Neoprene with orange stitching and has a lattice “Raschel” that gives the illusion of depth, black with orange background. The carpets of this pick up are aluminum with some holes and are placed a few millimeters above the floor. The purpose of this is to allow the occupants to clean your shoes and ensure a better grip.
Within the Colorado Rally, another item that stands out is the internal structure of occupant protection (cage), which facilitates the placement of extra equipment such as cameras or auxiliary lighting for the browser.
And speaking of pilots and navigators, the Colorado Rally Concept, offers a GPS navigation system of last generation and also a Hydration Pack. The latter is thermally insulated boxes containing an isotonic solution for hydration of the occupants, which passes through small tubes connected directly to the hull of them, allowing them to stay hydrated throughout the competition without removing from the road . In addition to these two cases, this concept has additional tool boxes and a first aid kit.
Beitragvon Kevman » Freitag 17. Juni 2011, 12:33
........ja, Korea lässt grüßen....
Dimostines
Beitragvon Dimostines » Freitag 17. Juni 2011, 18:26
Sind die roten Dinger vorne und hinten Handschlaufen mit denen du dieses Ding besser wegschmeißen kannst?
