Mopar 271cui V8 difference?
- Ivko
worin unterscheiden sich der 273er mit 180hp (2barrel) und 235hp (4barrel)? liegt der leistungsunterschied nur an folgenden komponenten:
-4fach vergasser#
-4fach ansaugspinne
-andere nockenwelle
oder wurden auch weiter modifikationen im vergelich zum 2v durchgeführt?
danke im voraus
-4fach vergasser#
-4fach ansaugspinne
-andere nockenwelle
danke im voraus
- marvin
...Köpfe sind auch anders, daher höhere Kompression....
273 CID LA
The LA family of engines with its thin wall casting technique was introduced in 1964 with the 273. The new casting was much lighter and considered to be well ahead of its time. The new LA block would be the foundation for many great high performance engines and is still in production today.
The first LA was the 273, with a two barrel carb, and 180 hp (gross). By 1965, a four-barrel carb and high performance cam were available to push that to 235 hp; and, in 1966, a limited edition 273 with a 700 cfm carb and .500" lift cam put out 275 hp (gross). This engine is known as the D/Dart 273 and was built specifically to allow the darts to compete in D-Stock drag racing. It is not known for sure if any of these 275hp motors were put into barracudas.
Standard 2-Barrel 273 (1964-1967)
Bore & Stroke 3.6250 x 3.31 in.
Displacement 273 cu. in.
Compression Ratio 8.8:1
Power (SAE) 180 bhp @ 4200 rpm
Torque 260 lbs-ft @ 1600 rpm
Standard 2-Barrel 273 (1968-1969)
Compression Ratio 9:1
Power (SAE) 190 bhp @ 4400 rpm
Torque 260 lbs-ft @ 2000 rpm
4-Barrel 273 (1964-1966) Commando
Compression Ratio 10.5:1
Power (SAE) 235 bhp @ 5200 rpm
Torque 280 lbs-ft @ 4000 rpm
4-Barrel 273 D/Stock (1966)
Power (SAE) 275 bhp @ 6000 rpm
Torque 295 lbs-ft @ 4400 rpm
273 CID LA
- 300er440tnt
- marvin
- marvin
...ich gehöre nicht zur breiten Masse, ich fahre breite Masse!
